											Area_man wrote:Glad to hear that the update is finished. Unfortunately, it looks as though the link for the UN-EU version isn't working at the moment. Perhaps it's overloaded.
											DekaR wrote:I´ve tried to apply Non'EU firmware:Are you going to roll out OTA update (not local) ?
- Renamed a file from tar.gz to .zip.
- Selected settings-> local update
- he phons restarted in boot mode. showed "Error", and loaded as usually without updates.
											chammerbeck wrote:The Non-EU is a tarball..... The phone requires a zip file like the EU version. Can you re-post the correct
file format please......
											DekaR wrote:Thsnks to you for response. Do you plan OTA update?
