Hello!
Where i can find Tab8 original ROM/Firmware?
Thank you.
											Cruiser wrote:Hello!
Thank you.
blackview_admin wrote:Hello, sorry for the inconvenience, please contact the after-sale department support02@blackview.hk
											Cruiser wrote:blackview_admin wrote:Hello, sorry for the inconvenience, please contact the after-sale department support02@blackview.hk
Contacted them, no answer.
Any possibility to root? Treble? "No Wake On Charge" is crucial, as far as i know, this can be achieved with Xposed, which requires root.
TWRP for Tab8? Anything? Or do i really need to return itm cause it's not usable..
fastboot oem unlock
                                                   OKAY [  0.001s]
Finished. Total time: 0.002s
fastboot oem unlock_go
                                                   OKAY [  0.000s]
fastboot flash boot_a patched_boot.img
Sending 'boot_a' (17300 KB)                        FAILED (remote: 'Download is not allowed on locked devices')
fastboot: error: Command failedfastboot oem unlock
                                                   FAILED (remote: 'unknown cmd.')
fastboot flashing unlock
                                                   FAILED (remote: 'Not implemet.')
Sending 'boot_a' (17300 KB)                        OKAY [  0.735s]
Writing 'boot_a'                                   FAILED (remote: 'Flashing Lock Flag is locked. Please unlock it first!')
											Cruiser wrote:Ok, after all the hassle i have the boot image and i unlocked the bootloader from Developer Options but bootloader is still locked:
Sending 'boot_a' (17300 KB) OKAY [ 0.782s]
How come bootloader is still locked?
In fastbootd:Code: Select allfastboot oem unlock
OKAY [ 0.001s]
OKAY [ 0.000s]
In fastboot mode:Code: Select allfastboot oem unlock
OKAY [ 0.001s]
OKAY [ 0.000s]
											Cruiser wrote:UPDATE
I have unlocked the bootloader but now i'm in a situation, where i need to flash original firmware/ROM image but
SPD_Upgrade_Tool_R24.0.0003 and naturally neither SPD_Research_Tool_R24.0.0003 or SPD_Factory_Tool_R24.0.0003
(cause they appear to be identical or at least similar) do not detect my Tab8
I guess this is a driver problem, so can i also have the correct drivers please?
I'm obviously in a hurry with this. Thank you.
I also sent e-mail to support02@blackview.hk (no need to suggest that) but they didn't bother to answer to my first one so i'm not feeling very enthusiastic about this one.
As i understand someone with technical skills used to give support in this forum and now that person has been replaced with administrative one?
Why have a forum, when all your questions are being redirected to e-mail nobody bothers to answer.
