  • 1
  • 2
  • 3
  • 4
  • 5
  • 11
9900 Pro Android 10 Update
Mon Aug 31, 2020 7:16 am
Hi everyone!
9900 Pro EU version can update to Android 10 now, the UN-EU version is still testing now, please wait patiently, and we will notify you as soon as it come out.
EU means the European Union. If you live in an EU country, it is EU version, and if you not live in an EU country, it is UN-EU version, if you are not sure, please check the order.
Please download the below update file and check the phone settings-system-update system, click local update, choose the update file.
Please note that the phone needs over 30% battery, and this is only for EU version
https://mega.nz/file/iSxRQAjA#hVwMxQp0l ... aRZP7lTB_U
KNBnavarro
Re: 9900 Pro Android 10 Update
Mon Aug 31, 2020 9:35 pm
Phone update done successfully. Android 10 working on my phone.
None Flor camera or normal camera works .
Help !
KNBnavarro
Mon Aug 31, 2020 9:38 pm
Android 10 update successfully.
Flir camera doesn't work
Normal camera doesn't work
Gurkoel
Mon Aug 31, 2020 10:21 pm
jmsupery wrote:
Thermal camera doesn't work anymore. Application stop working every time. what needs to be done?
Had the same issue. Just clear the cache and storage of the myflir app.
KNBnavarro
Mon Aug 31, 2020 11:44 pm
Wipe all the memory from cameras and it will work again
Tue Sep 01, 2020 3:38 am
QuincyQuinn wrote:
Is the Non Pro getting this Android 10 update...???
Hi, 9900 can't get this update, it will not update to Android 10.
zimzia
Tue Sep 01, 2020 6:07 am
After updating to android 10, fingerprint only works when you unlock the phone with the button and 5 seconds after locking it
jmsupery
Tue Sep 01, 2020 6:30 am
I found out how to fix it. Before the application stop working go in application parameters and click to restore parameters. You need may be to experiment multiple times before you finally do it because you only have 1 or 2 second before application stop working.
zimzia
Tue Sep 01, 2020 7:58 am
What application? What parameters reset?
prascho
Tue Sep 01, 2020 8:21 am
Will there be an Android 10 OTA update or we need to use the local update only?
  • 1
  • 2
  • 3
  • 4
  • 5
  • 11
