Re: BV9900 Pro Android 10 upgrade
Mon Oct 12, 2020 7:09 am
Neviu wrote:
What to do if it was already updated to android 10 can i roll it back to 9? Whitout losing all files etc
Or will there be a fix in this month?
Since my phone keeps shutting off to blackview logo.
The method to upgrade back to Android 9 is the same as the method to update Android 10.
Mon Oct 12, 2020 7:10 am
MikeRotch wrote:
Please send a link with the previous android version.
Tue Oct 13, 2020 3:12 am
Hello, you can update it back to Android 9, the same way as the Android 10 update.
MikeRotch
Tue Oct 13, 2020 6:20 am
I'm not sure if i'm the only one who does not understand this standardized reply, but it is a bit dissapointing.
I know the process, that it has to be done the same way it was done with android. But I do not have the previous Android version for the bv9900pro. Where can I find it? From where can I download it? I only have the android 10 os but there is no info where is the android 9 version
kpanagi1
Wed Oct 14, 2020 6:33 pm
Hi, I have the EU version, I try to upgrade to android 10, setup starts, phone reboots to the green  screen trying to start the update and I get an error. phone reboots again an gets back to android 9.
valdax
Fri Oct 16, 2020 12:27 pm
Hi, when you give us a stable version of Android 10? Thank you for your answer.
Sat Oct 17, 2020 7:46 am
bsantha08 wrote:
The firmware for android 9. You suggested to downgrade android 10 back to 9 but without the ROM or image this cannot be done. Thx
Hello, here is the tool for you: https://mega.nz/file/HbpTQSbT#a-N4QTxDMivVUe04sTvPmO-0z6nOwwM876IHqfZ4hHc
Please send an email to me and I will send one file to you. My email: mary@blackview.hk
Sat Oct 17, 2020 7:47 am
Hello, please send an email to me and I just can send the file to you via email: mary@blackview.hk.
Thanks in advance.
kuschi125
Sat Oct 17, 2020 10:32 am
Hello, I only have problems with my Blackview bv9900 pro since the update to Android 10. It supports at least once a day. what can it be and what can I do about it, it more slowly.
bvmarek
Sun Oct 18, 2020 7:38 pm
He got the BV9900 phone for the A / B partition?
