Re: BV9900 Pro Android 10 upgrade
Tue Nov 17, 2020 11:00 am
tmile wrote:
blackview_admin wrote:
tmile wrote:
The New version is arrived to me via OTA.
After the upgrade I can not make any call from the phone, I  cleared the emmc and reset all data but no changes.
I can not use this device as a phone so I'am really reall sad and angry I payed about 400$ for nothing (or a brick).
I bought it about 2 month ago. I send mails and video to the support and no solution.
I think I anybody want to buy a rugged phone try to select another...
T. M.
Hello, sorry for the delay reply.
1. Have you ever tried to reflash the phone to verify it?
2.When you updated it, this problem happened?
3.Which kind of the SIM card you are using?
More questions, you can send email to me directly so that I can help you more efficiently, here is my email: mary@blackview.hk
Dear Admin,
I spent a lot of times with this phone what I sould like to use only and I don't thought I had to "hack" it time to time...
So after the OTA upgrade and 1 hour attempts I realized, if I select my carrier manually It connect to the carrier and possible to make calls again.
I wroute about it to the support and they the suggest I had to remove the (original) APN settings , I created a new one manually and set it to default and after it the automatic carrier selecting works again. "Voila"
but ...
I arrived it to the beginning. If the 4G network signal level is not enaough the phone connect to the 3G network but it works usually but sometimes not and switching is very slow and when I'am in a calling after a short times I hear the other side but the other side do not hear me. If i push my sim into another phone (android/iphoen too) they works on same network on same place.
When I have free time i try to record a call same time on both side and make a video about it...
Regards,
Tom Miletics
Enter *#9646633# in the dialing interface and find Netork selecting in Telephony, click to find SIM, select the inserted SIM card, and select lte/ma/UMTS/GSM in the options in the screenshot.
Tue Nov 17, 2020 11:01 am
Dave clax wrote:
Dave from US.
  had the 9900Pro for about 3 months now.  I am very frustrated at the delay in getting Android 10.  The current (9) Android version is awkward and klunky.  Apps stop running in the background, web access locks up a lot, no separate app page accessible with a swipe up.  I am hopeful that most of these issues will resolve with Android 10, but the pace  of rollout is glacial at best.  I will wait another week, but after that I will investigate other phone options.  Possible cheap sale of barely used US version 9900pro coming soon!
I really want to love this phone, but Blackview support is tepid at best.....
Hello, could you please record a video for us to check this problem? Please send an email to here: support02@blackview.hk
Tue Nov 17, 2020 11:02 am
hollywoodwheels wrote:
Hi all, I'm Fabiano and I'm writing from Italy. I'm an happy owner of this phone (it's my second Blackview, the previous one is a BV9600).
I'm very satisifed with my new BV9900 Pro (received from Amazon with Android 10), but with the last firmware update I noticed a drop in battery life (during the night, if I put the phone in airplane mode, the phone lost 12% charge the morning after (and there are no apps in backgrounds, all closed). Before the firmware update the battery life was better.
Have you a solution for this or are you planning to resolve this issue in the short term? Thanks!
This is to clean up the memory in the background. It may be that the apk is running too much, causing the background apk to consume power after the screen is off.
hollywoodwheels
Tue Nov 17, 2020 11:10 am
I clenead up the memory closing all the apps (I tried closing one by one apps but also pressing the X button to close all the apps in one go.
The phone already had Android 10 at the time of purchase, but before the firmware update (with the last version: BV9900Pro_EEA_S900AA_V1.0_20200817V05_20201014-1302) I have not this kind of problem.
Benny
Thu Nov 19, 2020 7:03 pm
Hello guys, is there some news about the Android 10 update?
Any idea when I could be stable and available?
Kind regards
tmile
Thu Nov 19, 2020 8:52 pm
tmile wrote:
Dear Admin,
but ...
Regards,
Tom Miletics
Hello Admin,
Thanks for your reply. I'am sorry for my typos in my previous post.
The LTE/UMTS/GSM option has selected on this screen already previusly, there is no "lte/ma/UMTS/GSM" option, so i change nothing (now).
T. M.
Tamas Miletics
phonebs
Thu Nov 19, 2020 11:12 pm
Hi, on the official Blackview website they sell new BV9900pro updated to Android 10 for EU and NON EU version.
Is there a stable Android 10 update for NON EU version or  are those phones new hardware revision that do not have all problems mentioned here in this forum with Android 10?
Fri Nov 20, 2020 8:46 am
Khomotso1985 wrote:
So how can I get Andriod 10 for NV 5900, I what a dark mode plz help
This is the reflash tool for you: https://mega.nz/file/HbpTQSbT#a-N4QTxDMivVUe04sTvPmO-0z6nOwwM876IHqfZ4hHc
Fri Nov 20, 2020 8:52 am
This is the reflash tool: https://mega.nz/file/HbpTQSbT#a-N4QTxDMivVUe04sTvPmO-0z6nOwwM876IHqfZ4hHc
Sat Nov 21, 2020 7:48 am
Kind regards
Hello, sorry for that. The fingerprint and thermal imagery camera problem is still being checking and unstable, please don't update it.
