Spirtoylis
Re: BV9900 Pro Android 10 upgrade
Mon Oct 19, 2020 12:48 pm
blackview_admin wrote:
valdax wrote:
Hi, when you give us a stable version of Android 10? Thank you for your answer.
According to news, this week.
I just hope for a OTA update
eqvitos
Mon Oct 19, 2020 6:20 pm
Hello, gentlemen. Updated on Android 10 despite what they wrote bad. The flight is excellent. Updated quickly.
Yes, My FLIR did not go the first time. Stop and clean the app's memory help. FLIR works more faster that before.
Finger scanner Yes of course does not always work quickly. I could be wrong, though.
I haven't found any other bugs yet. I'll find it and write it.
Now all apps are in a separate menu. On the desktop, you can install applications to your liking.
Tue Oct 20, 2020 4:08 am
kuschi125 wrote:
Hello, so if I heard that correctly, will there be another working Android 10 update this week?
Do I have to delete the non-working version or something similar?
As I said, every day the phone crashes once, either with the Blackview logo or with the Andriod symbol and error sign.
Will the update be published here on the website or is it available as an update on the smartphone?
Hello, please don't take action at present until we announce all information.
Tue Oct 20, 2020 4:11 am
yes. OTA will be updated.
Tue Oct 20, 2020 4:12 am
Thank you for your feedback and that would be useful for us.
MikeRotch
Tue Oct 20, 2020 6:19 am
Please also make the slow motion video shooting possible. It is a much desired function.
Thanks
Tue Oct 20, 2020 6:37 am
Thanks
Hello, I will feedback this idea to our engineer, thank you for your suggestion
MrMiyagi1211
Wed Oct 21, 2020 1:55 pm
Hi I also have the BV9900 Pro EU version and would like to know where I can download the Android 10 update.
Roberto8
Wed Oct 21, 2020 5:22 pm
The update is already Via OTA !!!
Angespar
Thu Oct 22, 2020 11:48 am
Hi Blackview, I'm Angelo and I am writing to you from Italy, after using bv9900pro with android 10 for over a month I can say that I am fully satisfied, the only thing is that I no longer see the battery usage as a percentage of every single application since last full charge, all applications give me 0% even if used for hours, for the rest I am delighted. By the way, today 22/10/2020 there was a firmware update of about 100Mb for bug fixed, but nothing has changed. Anyway congratulations, a few days ago I also bought your blackview Tab8 with android 10 all perfect, excellent Rugged smartphones and tablets!
