aurybv6300
BV 6300 pro Compass calobration
Fri Aug 21, 2020 9:24 pm
Hello, i Just bought the bv6300 pro, and i Just found that the Compass Is not working well. I tried with manual calibration but It doesnt work at all. Searching on the net, i found some information about a similar problem with the bv9500, that was solved with a firmware update. I suspect the problem could be similar, cause i can see that the magnetic sensors work correctly but the response of the compass Is not consistent with that. I would like to know if someone else has the same problem with that model, cause if it's just mine i guess i will need to send the phone back. Instead, i suppose that blackview will provide a corrective update.
Re: BV 6300 pro Compass calobration
Tue Aug 25, 2020 9:08 am
Hello, you can enter *#87# to calibrate the magnetic sensor in the place where you can call first, and calibrate in the toolbox. When the calibration is successful, there will be a vibration prompt
Paulhenry
Tue Aug 25, 2020 10:41 am
Hi admin i just want to ask about the fucos of macro shot of bv6300 pro because if no fucos, macro shot is fail you cant fucos the subject you need.. thanks
Users browsing this forum: BryceWah, RupertLiela, WayneWeifs and 2 guests
