Freddy
WiFi Bluetooth Problems
Mon Aug 01, 2016 8:55 pm
My Wi-Fi slows down if Bluetooth is turned on. upstream is alright. The problem is all the same even it's 2.4 or 5 GHz. How can it be?
Re: WiFi Bluetooth Problems
Tue Aug 02, 2016 7:47 am
BV6000 supports 5G wifi, it is very fast.
Your wifi can work properly when Bluetooth is turned on ?
Best regards,
Admin
