ogghi2
FLIR libraries etc for other ROMs
Tue Jul 07, 2020 10:17 am
Hi there,
I hope this does not get deleted right away.
Please, could you get some of the code open sourced so the FLIR camera also works with other ROMs?
You could actually save a lot of $$$ in development time on your side. The GSI / LOS community is strong in keeping up with development. All is needed is to get online some sources.
There are plenty of users that would be happy around here!
Best
ogghi
Re: FLIR libraries etc for other ROMs
Wed Jul 08, 2020 9:53 am
ogghi2 wrote:
Hi there,
Best
ogghi
Hello, thank you for your suggestion, I will feedback your idea to our technical department.
sams
Wed Jul 08, 2020 4:29 pm
the BV9800 pro have a standard FLIR sensor. You can download the sdk directly from the FLIR developer page https://developer.flir.com/mobile/flirmobilesdk/
(You need to register)
FillLog
Sun Jan 24, 2021 6:49 pm
What about BV9900 Pro,  What FLIR  SDK is used for the Lepton in that phone?
I DID NOT enter water only put "Waterproof" BV9900 Pro in pocket of wet shorts
phone wont turn on + lenses are fogged
Blackview is not WATERPROOF - it cant last 1Km walk in wet shorts
paid $569 USD
NO WARRANTY!
