Mreaves
No unified app menu?
Mon Jul 06, 2020 5:49 am
I switched to Blackview from Samsung. While I enjoy the phone, I can't seem to find any sort of unified app menu with the option to pick and choose what apps go to the home screen. This is painfully similar to ios devices. Am I missing a feature? Or am I forced to manually place my apps into folders to reduce clutter on my home screen?
Re: No unified app menu?
Mon Jul 06, 2020 6:02 am
Hello, you need to place your apps into the folder.
sams
Mon Jul 06, 2020 8:46 am
Noooo...
Like on every Android devices, the home menu is just an application. You dont like the stock one? Choose whichever you want from the store or somewhere else!
Check this topic https://bbs.blackview.hk/viewtopic.php?f=286&t=535094&p=914820#p914820
Bplaizier
Mon Jul 06, 2020 2:07 pm
So I recently came from a Samsung phone as well, the Note Edge. I had the same question as you, where's the app button? I really have been accustomed to the Samsung home screen since I've had one for the last eight or nine years. So not having an app button that allows you to declutter the home screen was a big issue for me so I played around with a few homes green apps and found one the play store called the Galaxy S launcher that I really like, there are several out there that will give you the app option on the home screen. I liked this one because it was closest to the Samsung Samsung home screen that I had been using. It puts the apps alphabetical order when you click on the app button which makes it easy to find apps that I don't use often. Unlike like stock home screeen app (Quickstep) that comes with this phone. I have been using it for about a month now and it seems with no problems yet, knock on wood. I have and iPhone for work and I really don't like the home screen on that which reminds me a lot of the one on the 9800 no app button and can only create folders.
salto
Mon Jul 06, 2020 3:57 pm
I use Evie launcher for many years on different devices. I love it. Easy, customizable, free, well made.
Mreaves
Tue Jul 07, 2020 4:41 am
Thanks! I have always used Galaxy devices. I guess I was missing out.
Tue Jul 07, 2020 6:36 am
sams wrote:
Noooo...
Hello, thank you for your information here, can you contact me via email: mary@blackview.hk?
