Cybermatos
URGENT! Service activation problem in accessibility settings.
Sun Jul 05, 2020 7:36 am
Hello.
I purchased a Blackview BV9900, and I have a problem.
I installed some applications on this phone, I went to SETTINGS ---- ACCESSIBILITY ---- DOWNLOADED SERVICES to enable the programs I want. But when I enable them manually, they automatically disable a few minutes after, or when the phone is restarted.
My question is how to keep the programs enabled.
I installed the last update of android system, and disabled the battery optimization of the programs I want .
Thank you.
Re: URGENT! Service activation problem in accessibility settings.
Mon Jul 06, 2020 6:43 am
Cybermatos wrote:
Hello.
Thank you.
Hi, sorry for the inconvenience caused to you. In order to solve your problem more efficiently, please send your problems to support02@blackview.hk, and then our support will contact you soon. Thanks.
