dathoschy
BV9700 Pro and a 128GB SD Card
Thu Jul 02, 2020 1:00 am
Hi, I've only recently got the BV9700 Pro.
According to the description, it is also possible to use a 128GB SD card here.
Unfortunately, the software strikes when formatting the card. The process is canceled at 40%.
How do I get the card on my cell phone?
Re: BV9700 Pro and a 128GB SD Card
Thu Jul 02, 2020 6:14 am
Thu Jul 02, 2020 6:18 am
This is the memory configuration
dathoschy
Thu Jul 02, 2020 6:27 pm
Not only. If I look at the technical properties of the cell phone on the Blackview website, it says that even a 256 GB card is possible.
That means for me, if you can use a 256 GB card, 128 GB should also be possible ...
Otherwise, this would be misleading information if memory cards of this size cannot be used.
