Mafa1
Stock ROM download
Mon Jun 29, 2020 2:10 pm
Hello @ blackview_admin,
could you please provide the download - link for
BV9900 PRO Stock ROM?
thanks,
Mafa1
Re: Stock ROM download
Tue Jun 30, 2020 9:55 am
thanks,
Mafa1
Euro version: https://mega.nz/file/bGo0hYhA#9uxp2IOSMQ0Msq03gcf6D_J9DixFErO4Nh81qNCbsGM
Non-Euro version: https://mega.nz/file/2KoUUSiQ#LVg-bt6-B9QF1uSxfljrC8kJ9GbTfF3ZDXNOksRDOXA
bohunmike@gmail.com
Tue Jun 30, 2020 12:12 pm
When will this ROM be made available by OTA?
Mafa1
Wed Jul 01, 2020 4:35 pm
thanks,
Mafa1
thank you for the upload...
after flashing i see the following message
any idea how to solve it?
EDIT:
solved, flashed the non-euro version by accident
And_User
Sat Jul 04, 2020 4:54 pm
I 'm on manual updates and i downloaded the 20200601V09-version this afternoon OTA. So they are available now.
Regards And_User
And_User
Sat Jul 04, 2020 5:20 pm
Little corretion, the links above provide Roms Version 20200609V03 witch are not available OTA until now.
@ blackview_admin
Please confirm that the links are correct and help with an instructionguide for manual/local update. From my side of view the links have to be switched because of the "...EEA..." and "...AA..." nomination.
Local update with the wrong file could end up in trouble ...
Regards And_User
Mon Jul 06, 2020 6:54 am
thanks,
Mafa1
EDIT:
Hi, sorry for the inconvenience caused to you. In order to solve your problem more efficiently, please send your problems to support02@blackview.hk, and then our support will contact you soon. Thanks.
