Srivats kannan
I don't find WPS connecting option on my WiFi settings
Sun Jun 28, 2020 8:30 am
I tried to connect with a WiFi network by wps but I couldn't find wps options on my WiFi setting, tried different tricks to find wps but I couldn't.
Anyone has the same issue as mine and how can I find the WPS connecting option on my WiFi settings or do I need to enable something to get the WPS connecting option?
Tia
Re: I don't find WPS connecting option on my WiFi settings
Mon Jun 29, 2020 6:26 am
Tia
Hello, Tia, The WPS is one of the Applications???
sams
Mon Jun 29, 2020 12:01 pm
Tia
Hi Tia. WPS was removed from Android 9 and up by google. It's the same for every phone of every brand. Blackview have nothing to do with it.
WPS is an unsecured way to connect to a WiFi network and a huge security risk. You shouldn't use it anymore and disable it on your router/access point.
Dude, you are a phone company forum admin, I feel bad for you :(
