Aruet'al
BV9600E issues(waterproofness and battery life)
Sat Jun 27, 2020 12:59 pm
I know it's an E, not the Pro, but close enough still, and I don't believe the issues I've been having are due to minor software and hardware differences as they are both based on common hardware. Feedback has already been sent just earlier today but there hasn't been an email reply yet so I hope to hear some user input.
First, the waterproofing seem to have...issues.Primarily there are clearly water droplets behind the flashlight window.No way to tell if it's just a minor localized problem around the camera assembly as I haven't ripped the back plate of yet. I've only dunked the phone in like 4 inches deep soapy water for half a minute every other day, which should, per the IP68 rating, not ingress into the phone.
Second, the battery life seems to have shortened significantly after the phone rebooted itself last time after another rinse. I mostly run Chrome, YouTube, and some other video/conferencing apps for the better part of the day. Before the rebooting, the phone should last approximately two days of work-hours of Chrome, YouTube,Zoom,and the occasional gaming session.Now the battery prediction(assuming same rate of discharge for the same apps being run) has gone to somewhere between ten to forteen hours from full to nil(6-10%charge per hour,from my observations).This issue is quite noticeable and abrupt as I never liked my batteries under 50%,even if it'll still have several hours of runtime left.
Zorqan
Re: BV9600E issues(waterproofness and battery life)
Wed Jul 22, 2020 2:01 am
I thought my battery life was ok (or at least it is much much better than my previous phone (iPhone 6s), but I don't use a lot of video (zoom or YouTube).  Not sure I would get anything like 2 days if I used them a lot.  I mostly use things like Chrome, Twitter or Google, and Outlook etc
My issue with the BV9600E is that tap and pay only seems to work sometimes.
Doesn't seem to matter if I use Google Pay or my Bank's own app, it mostly isn't working - will work one day at, say Macca's, but the next day it won't.
joe tigercat
Sun Jul 26, 2020 5:32 pm
your battery drain problem is almost certainly a rogue app. i had this also, and not wanting to identify the app, i just reset the phone. that solved it. after charging, i was losing only 1 percent in 3 hours. if you don't want to reset your phone, try starting the phone in safe mode. if the battery performs as it should, you'll have to start removing apps
Tue Jul 28, 2020 7:33 am
Aruet'al wrote:
我知道它是E,而不是Pro,但仍然足够接近,而且我不认为我遇到的问题是由于软件和硬件的微小差异所致,因为它们都是基于通用硬件的。反馈已经在今天早些时候发送,但是还没有电子邮件回复,所以我希望听到一些用户的意见。
首先,似乎出现了防水问题,手电筒窗口后面显然有水滴,由于我还没有撕掉后面板,所以无法判断这只是相机组件周围的一个局部问题。每隔一天我只用4英寸深的肥皂水将手机浸入水中半分钟,根据IP68防护等级,应该不会浸入手机中。
其次,在上次重新冲洗手机后重新启动手机后,电池寿命似乎已大大缩短。我大部分时间都在运行Chrome,YouTube和其他一些视频/会议应用程序。在重新启动之前,手机应持续大约两天的Chrome,YouTube,Zoom和偶尔的游戏时段的工作时间。现在,电池电量预测(假设正在运行的相同应用的放电率相同)已介于从充满电到零电量需要10到14个小时(每小时充电量为6-10%,根据我的观察)。这个问题非常明显且突然发生,因为我从来不喜欢电池电量低于50%的电池,即使它仍然有几个小时的运行时间剩下。
你好,这是正常现象,电池本身不大,可以使用10-14小时是正常的
juandi34
Fri Sep 04, 2020 1:20 pm
On BV9600E cannot change notifications LED color: Always BLUE.
This phone has Android 9, like BV9700Pro ... so in this one applications can use it´s own configuration.
When can we have a firmware update correcting this issue  ????
BV9600E User
