ntpt
Bv5500pro Whatsapp problem
Thu Jun 25, 2020 8:39 pm
Hi ,all,
I buy a bv5500pro phone  because I break my old samsung. But there is  a big problem for me.  my key customer  use whatsapp excessivekly and it is expected  that I  am ONLINE just everywhere  .
But whatsapp keep randomly disconecting while phone is not used (locked).   After several -about ten minutes when lying  on desk for example, whatsapp connection to the phone is lost .  So there is lost connection to whatsapp web too. So from point of view of my customers I AM UNAVAILABLE . No notoification, no beep, no messages  even on PC. To go back to normal i must manually unlock  the phone and click on whatspp icon. An then, all lost messages  apear...     this behavior is unacceptable
I try to fix it by disabling wifi and leave only a mobile data. I try to fix it by settings  in batery , disabling duraspeed, several factory reset  and uninstall and reinstal lwhatsapp, etzc.,  but no luck.  Any solution ?  I just need ti be available on whatsapp always (and need to be protected by automatic phone lock and pin).
Re: Bv5500pro Whatsapp problem
Sun Jun 28, 2020 8:09 am
ntpt wrote:
Hi ,all,
This is a software problem, and you have to make sure that your VPN connection, I have encountered such a problem, if you do not connect WHATSAPP will automatically disconnect, this is not a problem with the phone。
ntpt
Sun Jun 28, 2020 7:13 pm
blackview_admin wrote:
ntpt wrote:
Hi ,all,
I do not use any vpn . just plain mobile data
Mon Jun 29, 2020 6:08 am
ntpt wrote:
Hi ,all,
Hello, If you want to use Whatsapp, you need to use the VPN.
ntpt
Wed Jul 08, 2020 8:24 pm
please any explanation I c\an  not use whatsapp reliably on your phone without vpn ? what kind of vpn and how I can get one and setup ?
Thu Jul 09, 2020 3:47 am
ntpt wrote:
Hi ,all,
Hello, You need to ask for your local internet.
