Orionix
Screen rotation
Wed Jun 24, 2020 4:21 am
In my Blackview BV9900 Rotate the screen by just moving the phone a little and it no longer returns to portrait mode and stays horizontal. This also affects the camera by capturing head or side shots. How can i fix this. Thank you
Re: Screen rotation
Wed Jun 24, 2020 6:31 am
In the drop-down box, select Cancel Auto Rotation. .
Re: Screen rotation
Wed Jun 24, 2020 6:39 am
Go to *#87# to calibrate the gravity sensor
neils
Re: Screen rotation
Wed Sep 09, 2020 6:50 pm
I have the same problem. What is *#87#? How do I calibrate gravity sensor?
sams
Re: Screen rotation
Thu Sep 10, 2020 9:44 am
Launch the "Phone " app
Tap on the keypad (center bottom)
type *#87#
Tap on MMI1 > Single test > Gravity Calibration
Callum
Re: Screen rotation
Thu Sep 10, 2020 9:18 pm
Hi I have just received my 9800 pro and it doesn't seem to auto rotate, also some of the toolbox features don't seem to move as I would have thought, I tried the gravity calibration and one of the circles does not seem to end up in the circle outline
Re: Screen rotation
Fri Sep 11, 2020 6:00 am
Hello, Callum, You can go to the setting to change the auto-rotate and which toolbox features don't move as you thought?
Callum
Re: Screen rotation
Fri Sep 11, 2020 7:17 am
The gradienter, plumb Bob and picture hanging, as you rotate the phone the values either don't change or are not correct. I have tried turning the auto rotate on and off in settings but neither seem to make it work.
Alancash100
Re: Screen rotation
Fri Sep 11, 2020 8:10 pm
My new BV9900 has the same screen rotation problem as above. The screen will rotate to the horizontal but it won't rotate back to vertical. Your answers so for on this thread have not been helpful. If this can't be fixed I'll send the phone back.
Alancash100
Re: Screen rotation
Fri Sep 11, 2020 8:12 pm
My new BV9900 has the same screen rotation problem as above. The screen will rotate to the horizontal but it won't rotate back to vertical. Your answers so for on this thread have not been helpful. If this can't be fixed I'll send the phone back. You have advised another person here to calibrate gravity sensor, I've tried this but I can't understand how to calibrate it.
