TachoC
BV9800 pro don't recognize SIM 2
Fri May 29, 2020 2:48 am
Hello my bv9800 pro doesn't detect sim 2. I insert the sim in slot 2 and nothing happens. In settings this sim slot appears as empty when the sim card is in. SD card has no problem to be detected in this same slot.
Re: BV9800 pro don't recognize SIM 2
Fri May 29, 2020 3:48 am
Hello, you'd better contact our professional after-sale department: support02@blackview.hk
TachoC
Mon Jun 08, 2020 6:48 am
Hello where can I get the replacements of the Sim card slot 2. The card slot is damaged. When I insert the sim card, cellphone doesn't detect it. It appears as an empty slot even when the card is in there.
Mon Jun 08, 2020 8:08 am
TachoC wrote:
Hello where can I get the replacements of the Sim card slot 2. The card is damaged
Hello, could you please describe your problems clearly? Or you can contact the after-sale department directly: support02@blackview.hk.
TachoC
Mon Jun 08, 2020 4:01 pm
Phone doesn't recognize sim 2 when it is inserted in the respectively slot, (phone shows the slot as empty even when it is inserted). The Sim slot is damaged, pins don't make contact with the Sim card. So this slot needs to be replaced.
Tue Jun 09, 2020 7:01 am
Hello, May I know when did you purchase this phone?
TachoC
Tue Jun 09, 2020 5:31 pm
May 23th of this year.
Wed Jun 10, 2020 7:31 am
Hello, You can try to get the card tray with a thinner double-sided tape and re-insert the card to see if the line does not work. If not, you can only send it back for repair.
MarineJim
Thu Feb 25, 2021 12:53 pm
Hi. My 9800Pro has just started to ask to insert the SD card. The SD card was already located. I have removed and relocated, restarted multiple times. I have also formated the card but it is still not recognised. Please advise.
Fri Feb 26, 2021 3:23 am
Hello, which SD card you used?
Users browsing this forum: Google Adsense [Bot] and 5 guests
