sonqbano
Bricked BV8000 PRO
Sat May 23, 2020 2:16 am
Hi. Í need help. My tell das working fine i das 15% battery and suddenly even í pressed Power to call never get display on again.
I tried buttons but it is like bricked.
I tries using the charger and the sane happened.
The issue is the same that this video shows using power cable
https://www.google.com/url?sa=t&source= ... 1l4VQBWbSI
I live in Argentina and no blackview service jere
Tell me how to solve it
Regards
Re: Bricked BV8000 PRO
Sat May 23, 2020 6:04 am
Regards
Hello, sonqbano, You'd better contact our professional after-sale department: support02@blackview.hk.
sonqbano
Mon May 25, 2020 8:50 pm
i add MTK 67XX drivers in my PC but USB doesnt detect the device even with battery connected or without battery.when  plugging USB cable pressing Vol * or Vol-.
No way to detect the phone in device manager
iI need it detected in order to flash it
Regards
sonqbano
Mon May 25, 2020 10:11 pm
can you show me where is TP KCOL0 in mobo  in order to ground it to be detected
Regards
sonqbano
Sun May 31, 2020 9:30 am
Regards
I did but they never reply. I need to know test points locations on board to run Emergency Download Mode.
Can you tell me the locations?
Mon Jun 01, 2020 6:51 am
Regards
