gamerpaddy
FLIR keeps calibrating without the app open draining battery
Thu May 21, 2020 1:55 am
i used the thermal a few hours ago and now when its quiet i can hear the calibration shutter of the flir cam clicking.
the camera is still on but  the app  IS NOT running
i had this a few times now, it drained the battery much quicker (sudden slope in the discharge curve)
fix pls
Re: FLIR keeps calibrating without the app open draining battery
Thu May 21, 2020 5:48 am
fix pls
Hello, You've better contact the professional after-sale department: support02@blackview.hk
ZeldaMaster501
Tue Jun 09, 2020 8:40 pm
fix pls
I've noticed that I have to manually kill A LOT of my apps because none of them seemed to go to sleep.  Try going into the app section of settings, find the FLIR app, and "force close" the app.  I've found that apps like Servicely automatically force close apps when the screen is off.  It's saved a crap ton of my battery while I'm not using my phone.
nwdst
Thu Jun 18, 2020 9:32 pm
The latest version of the ROM has an option under setting called DuraSpeed.  I have been using it and I can get 4 days off a single charge with light use.  If you carry over apps from a previous phone, they may be draining your battery.  There is an option in android to look at the app usage of your battery.
The latest ROM image works relatively fine for me.  No debilitating issues yet.
