zforum69
Wireless charging
Tue May 19, 2020 1:07 pm
On this phone the wireless charging receiver does not appear to be in the centre of the phone.  From my testing the wireless charging pad needs to be one third up from the bottom of the phone, approximately in line with the side ventilation holes.
Z
bushmen
Re: Wireless charging
Fri Jun 05, 2020 11:10 am
I have a problem with my wireless charging of the phone. You have to position the phone on a very precise point for it to charge.
What is the recommended wireless charger for the BV9900 Pro?
Sat Jun 06, 2020 6:57 am
Hello, you can try to use 10W of QI protocol, and put it in the right position.
stepaniz
Wed Jun 10, 2020 6:23 pm
What do you want to do ?
New mailCopyhow do you activate the 10W of QI protocol?
I don't find any setting with these features.
Thanks
Thu Jun 11, 2020 6:51 am
Thanks
You need to purchase this USB
Thu Jun 11, 2020 6:55 am
Thanks
You need to purchase wireless charger
stepaniz
Thu Jun 11, 2020 5:33 pm
I already have the wireless charger.
It works great with the bw9700pro but it doesn't work with the bw9900 pro
