nolkercb
verifying the BV9800 Pro is compatible with Verizon in USA
Mon May 18, 2020 8:09 pm
Verizon cannot confirm without a IMEI number. They suggested asking for one to use to verify compatibility on their end.
Re: verifying the BV9800 Pro is compatible with Verizon in USA
Tue May 19, 2020 7:02 am
Hello, you'd better contact the professional after-sale department: support02@blackview.hk
nolkercb
Tue May 19, 2020 9:23 am
Thank you. I have sent them an email.
ZeldaMaster501
Wed May 20, 2020 9:57 pm
I can confirm that this phone does indeed work with Verizon.  I'm currently using it on a Tracfone plan which uses Verizon's network.  The signal is pretty much the same as my old phone.
ZeldaMaster501
Wed May 20, 2020 9:58 pm
Also, data works as well!  I forgot to mention that..
nolkercb
Thu May 21, 2020 5:49 am
They told me it will work with Verizon
