Ophe_621
Custom Ringtone
Mon May 18, 2020 8:02 am
Is Anyone know how to change ringtone in BV9800 pro to custom media like .mp3 or .mp4 from local storage ?
I already try to change it but not successful...
Thanks..
Re: Custom Ringtone
Tue May 19, 2020 9:45 am
Ophe_621 wrote:
Thanks..
Hello, sorry to reply to you, you'd better contact the professional after-sale department: support02@blackview.hk
zforum69
Re: Custom Ringtone
Tue May 19, 2020 8:34 pm
Ophe_621 wrote:
Thanks..
Your post mentions the BV9800 Pro, but you posted in the BV9900 Pro forum. Which phone are you referring to? I have both and changed the ringtone to one of my own without any issue, it was a very simple and straightforward process. Exactly what did you try to do?
Z
