Re: BV9800 PRO Restarting after boot
Sat Apr 11, 2020 8:46 am
Krieger wrote:
Good day all.
I recently got my bv9800 pro. After going through the setup proces, almost immediately it started doing this.
So what happens is, I start up my phone, enter my pincode. I can do everything,and as long as my screen stays active, it will work ok. But as soon as the screen will go to sleep mode, after a few seconds it will switch of, and on again.
I haven't done anything out of the ordinary, it's doing like this straight out of the box.
I hope to have informed you enough.
Thanks.
Martijn
hello, sorry to reply you late. May I know when did you start to use it and why it happens suddenly? if you can describe it clearly, we can help you deal with this problem soon. Please let me know.
Sat Apr 11, 2020 8:55 am
The apk is set to open by default in the Speedmaster, and in the intelligent auxiliary function-check whether the application limit is open by default, if it is open, go in and choose not to limit.
