vankosk
BV6000 cannot enter to engineer mode and cannot update more than the V01_20161216
Thu Apr 02, 2020 1:28 pm
Dear Sir
I update my BV6000 to V01_20161216 by local file and now i have android 7.0 ,i tried to step up to the other update but nothing.Also after the update the microphone volume turn low and if i put *#9646633# it comes to engineer screen but it is telling to access from develop settings and closes.Waiting your prompt reply thanks in advance.
Re: BV6000 cannot enter to engineer mode and cannot update more than the V01_20161216
Fri Apr 03, 2020 6:35 am
vankosk wrote:
Dear Sir
Hello, sorry to reply you late. This is the need to open the version number in the settings, click 4 times and the developer options will appear
