VladV
CPU 100% load all the time - even after hard reset
Thu Apr 02, 2020 2:34 am
A week a go my CPU usage is constantly at 65-100% load, the battery drains out quickly. Caused by system_server process. It looks like 4 cores are always 100% loaded at 2392mhz. I've tried to do hard reset (reset to default state, erased all data). Nothing helps, please advice what can I do?
Kind Regards,
- Vlad
Re: CPU 100% load all the time - even after hard reset
Fri Apr 03, 2020 6:33 am
VladV wrote:
Kind Regards,
- Vlad
Hello, sorry to reply you late. This is the need to open the version number in the settings, click 4 times and the developer options will appear
