[size=175][font=arial, sans-serif]Hello, I bought a BV9500 PRO in June 2019 and yesterday when I fell from a height of 40 cm, the screen went black. I tried to turn on the phone, but only Blackview powered by android appeared on the screen, and then did the same thing again without being able to boot, while the temperature of the phone began to rise rapidly. I connected the phone to the charger, and the charging light came on, but not the screen. I disconnected it from the charger, opened the phone and disconnected the battery to prevent it from heating up the phone even more. The heated part of the mobile is the motherboard where the processor goes. Neither the battery nor the screen were heated, only the motherboard where the processor goes. Do you know that the overheating of the mobile could be due and why it does not start? Do you think I have a fix? The mobile has suffered only 7 falls of less than 1m in height, the last one was 1 month ago and I never had any problems. It has only been submerged in water at the time of purchase to verify that the mobile was submersible, 8 months ago.
[color=#000000][img=16x16]http://bbs.blackview.hk/data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAAAAUCAQAAAAngNWGAAAA/0lEQVR4AYXNMSiEcRyA4cfmGHQbCZIipkuxnJgMStlMNmeyD2dwmc8+sZgxYJd9ErIZFHUyYYD7fkr6l4/rnvmtl7+KitrqV/fq2Y5eLY3Z9S48eRLe7BmVZ9qhTLhQ0algzZWQOVKSsCF8OjAnwbxDTWFDUhPK/jMr1H6HE/IqRky2DyvCefuwItwZzodVoYRiLqMkVCXrwpJ9twZ+sgfDYEFYl8wIWxZ9uFf7zkallxlJh4YrLGsKjZRx7VGHhLqwgFUN45DGdb8MeXGpgB4ABZdeDcpZEY51A+hyLKz4S1W4MQWm3AibWtgWmk6dyISa1pSdyWTOlLXVp0+eL9D/ZPfBTNanAAAAAElFTkSuQmCC[/img]
[/size]
[/font][/color]
