DenverDeCoY
Can you enable tap to wake.
Fri Mar 27, 2020 2:27 am
Is there a way to enable "tap to wake" ? Most previous android phones I have used can be "woken up" by tapping the screen twice. With the BV 9500 Pro it does not respond when I tap the screen twice. I don't mind using the power button or finger print scanner, but I was wondering if there is a setting somewhere to enable this feature, thanks!
Re: Can you enable tap to wake.
Fri Mar 27, 2020 8:40 am
In the settings, there is a gesture, you can set this function.
