adrianmsmith
Can I update bv9800pro to Android 10
Sun Mar 22, 2020 9:24 am
Hi. Is it possible to update my bv9800pro to Android 10.
If so please could someone spend a little time to put the steps required in a reply.
I'm not a newb but I'm far from an expert
So a step by step would be very much appreciated.
Many thanks
Ade
sams
Re: Can I update bv9800pro to Android 10
Mon Mar 23, 2020 3:34 am
Hi.
Short answer : no
Longer answer : yes, probably, with a lot of knowledge, work and time for a poorly usable result. Or if Blackview decide to upgrade it. And they likely won't.
