vonmuller.axel
BV8000 not respond or restore
Fri Mar 20, 2020 10:58 pm
Hi! I can't start or restore my Blackview BV8000Pro phone!
It doesn't respond to the reset mechanisms, key on + vol min or vol max, when doing this it turns on a red light but then it doesn't turn on
I was using it to watch a movie on Netflix and it fell from a height of <1m onto a soft floor, image was frozen, and I tried to restart it... but never again respond! It is only a Black screen with this red led light in front!
Is there a mechanical way to restart it? By disarming it?
I live in Patagonia, Argentina, and there are no technicians working with Blackview... it's very unusual this cellphone.
I have it since May 2018 and it is in very good condition, due to its rusticity, it should not break!
I need help Administrator!!!
Greetings, Axel
Re: BV8000 not respond or restore
Mon Mar 23, 2020 2:38 am
Greetings, Axel
You can try to flashing your phone. Tutorial: http://bbs.blackview.hk/viewtopic.php?f=192&t=319505
If it can't work, maybe it need repaire.
