Ferry13th
FLIR build-in thermal camera
Thu Mar 19, 2020 11:35 am
Hi, I see in the specs from my bv 9800 pro that it has an build in thermal camera. How can I use it? Yeah it's nice if the right app to use it was installed from first use on out, but it's not!
And I tried to install the FLIR app, but that apps don't work because the ask me to connect the external FLIR camera.
So which app is supposed to be used for it?
Xtreme
Re: FLIR build-in thermal camera
Mon Mar 23, 2020 6:07 pm
Have you used the flir app of cat s61 yet? it should work just fine, at least for me. does this app not work? are you sure you got the pro version? The lens of the thermal camera is visibly different from the 2 normal cameras. what build number / firmware do you have? you can see at system information.
Orthodontist
Thu May 14, 2020 6:28 pm
Wow I'm with you 100% I have a 9800 pro and no thermal camera. I have not been able to make it work and it was the main reason I bought this model cell phone
Fri May 15, 2020 3:50 am
Hello, if you have any questions about the product, please contact our professional after-sale department: support02@blackview.hk
