To enter the test menu use the same code as for the other models in the 9500 family:
1. Open Phone call menu [as if you would call someone]
2. click the manual dial menu [at the bottom]
3. key in this code: *#87#
4. The factory menu should open [you will know when you see it]
5. On this screen select MMI2 or MMI4 [this is where it differs from other models]
6. Select Single Test
7. Find and select Distance Calibration [color=#2980b9][about the middle of the screen][/color]
8. Follow the instructions on the screen. A demonstration how to do it can be found here:
Hope this is useful for someone,
Regards
All credit to the guy who made the YT video!
