Bastich
Media Bar Color Issue
Thu Mar 05, 2020 12:42 pm
I had to hard reset my BV due to some technical problems (now resolved), but after configuring all the settings the media bar has a issue with the colors.
As you can see there is a dichotomy between these two screenshots. In the first one the color of the media bar is correct, but in the second one it changes to the secondary color of the device (a very light green).
Before the hard reset this color problem never happened and it is repeated in other aspects.
Thank you.
Re: Media Bar Color Issue
Sat Mar 07, 2020 5:52 am
Thank you.
We will fix it on next update version.
