Keeper
Bv9800 pro flir 120 or 150
Wed Mar 04, 2020 7:16 am
Re: Bv9800 pro flir 120 or 150
Wed Mar 04, 2020 9:40 am
Keeper wrote:
https://youtu.be/3BlAs0SGr4Y
The measurement is more accurate at a distance of 20 cm.
Keeper
Wed Mar 04, 2020 5:58 pm
Why does it show the temperature up to 120 degrees, and after I took a photo up to 150 degrees
salto
Wed Mar 04, 2020 8:52 pm
Just a minor bug on the app. Click on "flames" icon in the app and it will allow to measure higher temperature, up to 450C as I remember (try it).
By the way, is it possible to remove this limit? For example I don't need high accuracy on high temperature, I just want to know how high approx. it might be.
