When I perform a call, it always annoys me the fact that the default audio output is the loudspeaker. Even if I have bluetooth-enabled headphones connected.
I have to touch two times to select the proper audio device (Bluetooth, or just using the small speaker along with the proximity sensor)
Could this be changed somehow? It is really annoying, as I am always doing private calls at work and I have to perform these two extra steps.
Thank you.
