masot
null imei for bv6800 pro
Sun Mar 01, 2020 11:47 pm
hi dear admin,
my phone is null imei number, (flash costom rom).
how I reset them?
tnx
masot
masot
Re: null imei for bv6800 pro
Tue Mar 03, 2020 8:29 pm
hi,
I reset imei by SN_Write_Tool_v1.1916.00 program Very easy.
I use of db folder in calibration folder in stokrom file.
for MD_BD I use: "MDDB_InfoCustomAppSrcP_MT6750_S00_MOLY_LR11_W1630_MD_MP_V127_1_ulwctg_n.EDB" file.
and for AP_DB I use: "TK_MD_BASIC_PCB01_P_MT6750_S00.elf" file
masot
Chiogros
Wed Apr 29, 2020 7:04 pm
Install MTK engineering app
Open it > MTK settings > GPRS
Then look on box phone box for the factory IMEI, and write then for SIM1 and 2
Wish I helped you
Thu Jul 09, 2020 5:53 am
Atrax wrote:
same to me after rom upgrade
can you please provide a valid alternative to fix? mine has only 24h of life thanks!
Hi, sorry for the inconvenience caused to you. In order to solve your problem more efficiently, please send your problems to support02@blackview.hk, and then our support will contact you soon. Thanks.
