salto
Software Security Update
Thu Feb 27, 2020 7:34 pm
I have tried to pay via Google Pay today, but got error in apo that my Software Security is out of date. Current security update on my BV9800Pro is October 5, 2019. It is pointed in RED color. How can we fix this?
sams
Re: Software Security Update
Thu Feb 27, 2020 8:56 pm
I saw in another of your post that you use EdXposed. It can cause problems with some security/banking apps.
I have the same security update version (red flag), Magisk 20.3 and a few module installed. I don't have any problem with Gpay.
Does your phone pass the SafetyNet check ?
salto
Fri Feb 28, 2020 1:41 pm
Well good point, actually it does not pass, even with magisk hide... Need to find solution
salto
Sat Feb 29, 2020 12:19 pm
Ok, so now it's funny... I had issues, so I have flashed rom again and rooted with magisk again, now I do not have fingerprint issues on banking apos after reboot, but now GPay does not allow to add the NFC payment method because device "is rooted or altered in some other way". Previously I hadn't this problem and now with xposed module installed I actually pass safetynet on magisk app. The app is also set as hidden fot GPay. Any ideas how to make GPay work again?
sams
Mon Mar 09, 2020 11:53 am
Add to Magisk Hide :
Android Services Library
Google Pay
com.google.android.gms
com.google.android.gms.unstable
For the best stability do not add too many app/services to Magisk Hide, only what you need.
it's possible to pass the SafetyNet check with xposed installed but it does not guaranty that Gpay will work.
But Gpay (and any good banking/security apps) will never work if you fail the SafetyNet check.
jfarreola
Tue Mar 10, 2020 2:40 am
Aside the advised before, try thismodule in Magisk and follow its config instructions.
sams
Tue Mar 10, 2020 9:50 pm
The BV9800 Pro stock fingerprint is already valid and pass the ctsProfile check. You don't need Props Config for this phone.
To be clear, salto is talking about the Fingerprint Sensor and not the device's fingerprint (ro.build.fingerprint)
