Arnaud.nc
Macro photo mode
Wed Feb 26, 2020 7:46 am
Hi.
How Can i use the Macro photo mode ?
It's not automatic on the photo app !?
Ans how the depth captor works ?
Thanks
Regards
Khalil
Re: Macro photo mode
Tue Mar 03, 2020 2:43 am
You click the 4 squares at the top right corner and you will find Macro mode along few other modes.
Gdolan
Mon Mar 09, 2020 12:38 am
When you are on the camera app look in the top right corner there are 4 squares click it and macro mode is under that button
Hahasiah
Sun Apr 26, 2020 3:15 pm
To Switch under macro mode you have to click on the square image on top right of thé screen under camera app.
After you click on Macro Lens
