salto
[TUTORIAL] Remove Unlocked Bootloader Text
Tue Feb 25, 2020 8:43 am
I was annoyed by the text during boot like "Orange state... Bootloader unlocked... device can't be trusted...". So if You are like me, here is the solution for You.
[TUTORIAL - DO IT ON YOUR OWN]
YOU CAN MODIFY LK.img FILE ON YOUR OWN, JUST DOWNLOAD OFFICIAL ROM AND THEN FOLLOW THIS TUTORIAL: [color=var(--newCommunityTheme-linkText)][size=100][font=Noto Sans, Arial, sans-serif]https://forum.hovatek.com/thread-31664.html[/color][/font][/size]
OR
[FLASH IT RIGHT AWAY]
DOWNLOAD ALREADY MODDED LK FILE AND FLASH IT VIA SP Flash Tool: [color=var(--newCommunityTheme-linkText)][size=100][font=Noto Sans, Arial, sans-serif]https://mega.nz/#F!6skVUQII!3TaIzdSfv49VMwLpzqRCPQ[/font][/size][/color]
[color=var(--newCommunityTheme-linkText)][color=#1a1a1b][font=Noto Sans, Arial, sans-serif]P.S., When You flash using SP Flash Tool (as I did), You have to flash lk and lk2 (You set the same file for both fields, atleast that what I did and it works perfectly).[/color][/font][/color]
NOTE: If Your phone will not boot after You do this, it means You did something wrong. To fix it, simply flash original lk.img files in "lk" and "lk2" fields again and it will be fixed.
When You use SP Flash Tool, MAKE SURE YOU ONLY CHECK LK AND LK2 FIELDS. Cause if You also flash userdata, You may loose all Your files on the phone (I think so)!!!!
And Yes, You must understand what You do, I do not accept any responsibility for any damages or else.
Good Luck.
