xnotis
(BV9000 pro F) Android auto and apps are not synchronized with ford sync 3
Mon Feb 24, 2020 6:49 am
When i connect my mobile to my car Ford sync 3 i should automatically read android auto and other applications like sygic car navigation etc. With bv8000 i have everything working correctly but with bv9000 pro nothing. I've done cleaning wipe / cache, wipe / data, factory data reset but nothing. The phone is set to MTP file transfer. Please help.
Re: (BV9000 pro F) Android auto and apps are not synchronized with ford sync 3
Wed Feb 26, 2020 7:48 am
Check if your software version is the same
Alevesque2009
Sat Sep 19, 2020 2:50 am
I connect my phone to android auto with bv9600 using original cables. After 5 minutes or so, the phone and the android auto locks up, screen freezes and nothing works
