BasoSync
Do not connect to Wi-Fi with a hidden SSID.
Fri Feb 21, 2020 5:57 am
Re: Do not connect to Wi-Fi with a hidden SSID.
Sat Feb 22, 2020 2:10 am
Is it can connect to the normal wifi?
BasoSync
Mon Feb 24, 2020 9:51 pm
Yes, it connects normally to any Wi-Fi with an open SSID, as soon as you switch the SSID of the point to hidden mode, the connection is disconnected and is no longer connected. I asked to check this behavior of other owners of the BV9900, they confirmed this problem. Presumably this is not a hardware problem, but a software problem.
cfgungrave
Mon Apr 20, 2020 11:40 am
the same problem
normal WIFI is OK
Tue Apr 21, 2020 3:08 am
cfgungrave wrote:
the same problem
normal WIFI is OK
Sorry to reply to you late. You've better to contact our professional after-sale department: support02@blackview.hk
cfgungrave wrote:
the same problem
normal WIFI is OK
