Gdolan
Using the UVtest bv9900
Tue Feb 18, 2020 4:35 pm
How do you use/calibrate the UVtest as it dose not seem to read anything...or dose it need to be direct sunlight for the sensor to work....or do I need to leave it on the screen for sometime for it to calibrate?? Thanks in advance
Re: Using the UVtest bv9900
Wed Feb 19, 2020 7:22 am
The corresponding equipment is required to use UVtest for calibration. So you cannot calibrate yourself. Maybe your measurement takes longer, and don't block the sensor.
