chsmits
Realy waterproof ?
Tue Feb 18, 2020 12:00 pm
Hi, this morning I made snorkling with my phone.During half an hour and up to one meter down.
And now, the microphone is dead.
The question is : is that phone realy waterproof ?
Re: Realy waterproof ?
Wed Feb 19, 2020 7:12 am
I suggest you that contact your seller or our professional after-sales directly. They will help you more detail.
salto
Wed Feb 19, 2020 1:02 pm
I had other waterproof phone some time ago. After You take it out of water, You must give it a time to water come out of the holes, it must try a bit. For me (on the other phone), phone usually got back to normal within 3-6hours. I am talking about mic and speakers. On this phone - not tried yet.
Zefanya8
Wed Feb 19, 2020 4:48 pm
Same like me. Microphone dead. Some times, speaker too. It's distrub when I play game RPG. Because sound on-off-on-off.
Is it still in warranty?
Robylucche
Thu Apr 30, 2020 8:14 pm
Hello, the rear speaker of my Blackview 9800 Pro also presented a problem. washed with soap and water, then dried. When I went to hear the sound, it didn't come out clean, and it gurgled...., it seemed drowned! After a few hours, it resumed to work as well as before.... Now, however, I'm afraid to dip it back into the water... To you, how's it going now? Did this happen to you after it got wet
Tue May 05, 2020 8:48 am
Water may have entered the phone because it has been soaked for too long
Ivanka
Wed May 06, 2020 12:49 am
My phone usb-c rubber cover is not closed/fit properly. Is this condition will affect the waterproof system?
Wed May 06, 2020 8:57 am
Ivanka wrote:
Under normal circumstances, it does not affect, as long as you do not soak the phone for too long
ZeldaMaster501
Sun Jun 07, 2020 9:14 pm
That seems to happen to mine as well.  It goes back to normal after I leave it sit on something that absorbs water - towel, paper towel, etc- with no lasting effects.  This should be perfectly normal for any speaker that enters the water and thus it's perfectly normal for this phone.
Mon Jun 08, 2020 8:18 am
Hello, if you have any questions about that, please directly contact our professional after-sale department: support02@blackview.hk
