Hi, my temp sensor is stuck to 22 degrees and humidity to 47%... I even tested it in the fridge, it's Always the same values...
Is it hardware or software problem?
Mon Feb 17, 2020 4:24 pm
Tue Feb 18, 2020 3:22 am
garfield63 wrote:Hi, my temp sensor is stuck to 22 degrees and humidity to 47%... I even tested it in the fridge, it's Always the same values...
