subpota667
fast screenshot on bv6800 pro ?
Sun Feb 16, 2020 5:56 pm
Hello, I have a bv6800 Pro and I wonder if it was possible to do fast screenshots. Because when you want to do a screenshot by pressing the power and the volume's button, something appears, and asks you to confirm the screenshot, and so the screenshot is taken once you clicked on "okay".. It's not a serious problem but sometimes it may be a little bit crippling to not be able to take a fast screenshot..
So I was wondering if there was a way to solve this problem ?
Thank you
Re: fast screenshot on bv6800 pro ?
Mon Feb 17, 2020 9:00 am
Thank you
The bv6800 Pro phone can use gestures to take screenshots through settings. You can try to find the settings.
