Ioseba
Me2 with white noise
Sat Feb 15, 2020 2:30 pm
Well for short already tried engineering mode, disabled the google assistant i was using for good, now sadly off,
also turned off the bass improvement in audio options...alll the same: if nothing is playing, mic works fine, but if there is a call or im using a metronome for recording something an enormous white noise kills anything else.
So... What do I do?
I've tried posting some recorded audio to realise how it is, idk if those passed throwgh in this post.
My wild wild guess is that the mic is receiving feedback from somewhere at the sound reproduction event, but is weird it happens both with a headset connected (tried a couple tested in other device and worked fine) or nothing unplug at all.
If there is somdthing you think i should check with engineering or whatsoever im all ears, please ¯\(°_o)/¯
Re: Me2 with white noise
Mon Feb 17, 2020 8:46 am
So... What do I do?
I think you'd better contact our professional after-sales directly and tell them more detail.
