claudiodel
THERMAL CAMERA TEMPERATURE ERROR
Tue Feb 11, 2020 6:05 am
In the images I send you can see a towel, which is hung at room temperature of 20 degrees celcius, then you can see rolls of toilet paper, which are in the same environment. It can be seen that the temperatures are wrong.
Thanks
Hi, admin, the miodel P10000, work in Band 4 of LTE or 4g?
Regards
Re: THERMAL CAMERA TEMPERATURE ERROR
Wed Feb 12, 2020 7:55 am
Thanks
20 cm distance measurement is the most accurate。
sams
Wed Feb 12, 2020 12:55 pm
There is no pictures in your post. If your towel is or was just slightly wet, it will be colder, even if you can't feel it.
