finmars
calibrage de TOOLBAG
Sun Feb 09, 2020 7:00 pm
bonjour,
j'ai un petit probleme avec le toolbag qui n'est pas juste, le verticale ... n'est pas verticale  ! et ne ne comprends pas comment le calibrer avec height measure
pouvez vous m'aider ?
merci
Re: calibrage de TOOLBAG
Mon Feb 10, 2020 8:19 am
finmars wrote:
bonjour,
merci
You can have a try: Go to the dial interface and dial "*#87#".
finmars
Tue Feb 18, 2020 1:57 pm
Bonjour,
cela ne fonctionne pas mon , il existe toujours un decallage!
et j'en ai absolument besoin !!
mon appareil est il en panne ?
merci
it does not work my, there is always an unpacking!
and I absolutely need it !!
is my device broken?
thank you
Enrikez
Fri Feb 26, 2021 8:26 am
Hi, I have same problema with BV5500 Pro, how is possibile to solve or calibrate? I attach a photo where the plumb tool is out of 4°
Tue Mar 02, 2021 8:32 am
finmars wrote:
Bonjour,
merci
thank you
*#87#Select a single item to calibrate the gravity sensor
finmars wrote:
Bonjour,
merci
thank you
*#87#Select a single item to calibrate the gravity sensor.
Tue Mar 02, 2021 8:33 am
Enrikez
Wed Mar 03, 2021 3:30 pm
Thanks for tour replay.
I have follow this step:
Get into menù with *#87#
Select voice item_test
Then select g-sensor
After finish all nothing have changed,
Thu Mar 04, 2021 6:07 am
Hello, select the G-sensor, and put it on the page to calibrate.
Enrikez
Thu Mar 18, 2021 8:45 am
Hi, I have retry and make some re-calibration but it seems impossible to get a decent precision. On a perfect piano It still get 1grade error
