hristovski
No notifications, no dark mode
Sun Feb 09, 2020 12:52 am
  1. No dark mode
    Android 9 should natively have an option to select Dark Mode in Display Settings. This option saves battery power and it's very useful. A80 Pro doesn't have this option. Please include it in the next release.
  2. No (or late) notifications
    Settings -> Battery -> Standby intelligent power saving - this option might shut down messengers or similar apps that continue to run in the background. (there was a similar problem with Blackview A10, also)
hristovski
Re: No notifications, no dark mode
Thu Feb 13, 2020 7:37 am
Additionally, if you still have problems with the notifications you may try:
Settings -> Smart assist -> Auto clean memory - Add messengers, alarms in the White List although the option is off, it may affect the apps...
and also: Settings -> Smart assist -> Duraspeed may affect some applications.
