fellow
Google search bar
Mon Feb 03, 2020 9:27 pm
How can i remove the google search bar from my BV9900?
Re: Google search bar
Wed Feb 05, 2020 3:24 am
Sorry, the google search bar can not be removed.
fellow
Wed Feb 12, 2020 8:16 pm
Ok, too bad, then I have to root the mobile in the near future.
shaneprobinson
Fri Feb 14, 2020 8:33 am
You can remove to the google search bar by installing a different launcher.  I would suggest trying Nova launcher as a start.  Works similar but has more options then the default android launcher.
garfield63
Mon Feb 17, 2020 4:19 pm
Change your launcher... I use Microsoft launcher ans dont have this problem...
